Intake Gasket Removal
  • Thread starter Thread starter Blue's owner
  • Start date Start date Feb 25, 2017
  • Tags Tags
    intake gasket removal
Blue's owner
  • Feb 25, 2017
I have a 65 mustang 289. I'm swapping the 2bbl carb and intake for a 4bbl carb and intake. I'm a 71 year old novice at this attempt. The first challenge was loosing and removal of the intake. The major hurdle is removing the old intake gaskets from the heads. Just short of dynamite, I tried different liquids made for that purpose and various scrapers. Does anyone have any ideas? Thanks..
85ragtop
BTW, I like dudes.
475
123
NC
Feb 25, 2017
  • Feb 25, 2017
Welcome to stangnet. I'll move this over to classic tech for you.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Feb 25, 2017
  • Feb 25, 2017
Not a pleasant job . . . .
I scrape with hardware store type razor blades and then clean up with lacquer thinner followed by brake cleaner.
Blue's owner
  • Feb 25, 2017
Blue's owner
  • Feb 25, 2017
Thanks I bought blades today.
Blue's owner
  • Feb 25, 2017
zookeeper
3,415
63
109
Rogue River, Oregon
Feb 27, 2017
  • Feb 27, 2017
Just a little tip: when it comes time to re-install your intake, discard the cork end gaskets and use a thick bead (slightly wider than the end rail) of black RTV sealant. Let it sit for about 10 minutes until it "skins" over. Also, add a light coating of the black sealer around the water ports in the head (front and back) on both sides of the intake gasket. When it comes time to install the intake, cut the head off of 4 bolts, round off the end, thread into each corner of the cylinder head and use it as a guide to keep the gaskets in place. Then just unscrew the guides after you have a couple bolts in place.
Blue's owner
  • Feb 27, 2017
OK. Thanks. Do you not put any sealer on the rest of the gasket front or back?
Blue's owner
  • Feb 27, 2017
Thanks. Don't you put sealer on the rest of the gasket?
dennis112
1,561
36
79
Feb 28, 2017
#10
  • Feb 28, 2017
  • #10
Zookeeper does the install the same as I do. I prefer to use "Right Stuff" in place of the end seals. (Just a personal choice.)
Only put sealant around the water ports (light amount.) The remainder of intake gaskets around the intake ports should be installed dry. The reasoning is that many of the sealants (especially silicone) are not impervious to gasoline and can dissolve over time.
Blue's owner
#11
  • Feb 28, 2017
  • #11
Thanks so much for all the tips. I'm glad I joined. You've been most helpful....
zookeeper
3,415
63
109
Rogue River, Oregon
Feb 28, 2017
#12
  • Feb 28, 2017
  • #12
Nope, just a little around the water ports and nothing on the intake ports. My Dad used to use a spray sealer but I've always installed dry.
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
M
  • mnky99
  • Sep 5, 2025
mnky99
M
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
