I am putting together my motor, I received the fel pro 1250's for my tfs (unported) lower, which didn't match up at all on one side of the ports on my twisted wedge heads (unported). I called trick flow and they said to trim them. I trimmed them and went way into the blue. Is this OK?
i put it all together yesturday with the black goop on the ends as told. This morning I went out and started with the rest of the build. I didn't clean the lower enough and some oil went into the goop and caused it not to stick well...my bad...So I took it back apart..
My ? is would i benifit more getting the 1262's instead, since I killed my 1250's taking the intake back off...
Thank you for your help on this,, tony
