Intake issue
  • Thread starter Thread starter steelcityGT
  • Start date Start date Mar 11, 2004
steelcityGT
Glenshaw, pa.
Mar 11, 2004
  • Mar 11, 2004
I just installed an edel/5.0 performer and am experiencing an leak in the middle of the manifold on the passenger side. The car was driven twice
(20min & 35min)before I located the problem. I had torqued the lower to spec
before assembly and everything went like clockwork. The noise was not apparent at idle at all and could only be heard under load. When I located the
source I found 1 bolt to be almost hand tight and everyone I could reach loosened. I torqued down all I could reach and limped it home last night.(It
quieted down but not totally) My question is once I take off the upper and
re-torque eveything will this solve the problem or do you think I've already
caused gasket failure? Edelbrock says to use 16-18flbs. but trickflow and others use 20? Has anyone else had this problem with their performer?
Blowfish
11
S.F. bay area
Mar 11, 2004
  • Mar 11, 2004
Mine drove me crazy with a loud whistle sound , turned out to be the new 70mm throttlebody that I installed with the new intake. How does it run ? If it runs ok then check your plugs for a lean out condition, if the plugs look good , crank the stereo up and live big.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
