intake manifold
schiccc
78
still got the stock intake on my car and it already has e cam p heads 70 tb 75maf 24 lb injectors. think i can really get 35 to 40 hp if i put on a good intake. i want the car to pull to the 6250 right now it pulls to about 5800 before it quits thinking of typoon professional products and port match it
I don't think you'll pick up quite that much, but the stock lower is definitely hurting it. Budget alternative would be to have tmoss port your lower. Pretty good match with your p heads -- he's got some dyno data on some combos like that I believe. Much cheaper than aftermarket manifolds -- his ported lower makes the stock upper/lower HO manifold flow much better - not quite as good as the GT40/Explorer/Cobra intakes, but pretty close, for MUCH less money. PM him with your combo - I'm sure he'll share his thoughts on what you're contemplating.
