Intake Options
  • Thread starter Thread starter 5-2-Floor
  • Start date Start date Mar 9, 2007
5-2-Floor
Massachusetts
Mar 9, 2007
  • Mar 9, 2007
Recently purchased this car with several mods already done to it, but it's still running the stock heads and stock upper and lower intake. I'll be replacing the heads for AFR's, but I'm wondering what to throw on it for an intake. I like the BBK SSI Intake but I've never seen a 5.0 with it so I was wondering if it's any good or not? Then the other options are Trick Flow, Holley, Edelbrock, Etc. Please let me know what you guys are running or what's supposed to be a good intake to eventually run with AFR heads.
Aryan15
236
CA
Mar 9, 2007
  • Mar 9, 2007
When I get my new motor, im going with the gt40 intake. I was thinking of going with the bbk, but just can't spend that much on an intake. But in the 5.0 mag, the bbk performed very well amongst the other intakes. It looks good also and you can supposedly get the valve covers off without pulling the upper plenum. Good luck deciding.
Sicarius428
2,085
Mar 9, 2007
  • Mar 9, 2007
I would stay away from the slick looking BBK intake. The article that tested the BBK was a bit stacked from the setup they used. Depending on what you are going for and budget... Edelbrock, GT40/cobra/Explorer are great and proven for street cars with good low-mid torque. Typically TFS intakes don't truely shine till you hit 3kish rpm. It really depends on what characteristics you want from the car.
Kevin
4G-KDMP
935
CA
Mar 9, 2007
  • Mar 9, 2007
+ 1 for the gt-40 intake.
Mr Grim
58
  • Mar 9, 2007
Avoid the SSI intake for the street. Crappy fit (had to grind into the hood for clearance), too short for tall valve cover on the pass side, and you will lose a lot of bottom end.
4G-KDMP
935
CA
Mar 9, 2007
  • Mar 9, 2007
exactly the samething ive been/reading from others!
vikingpower
656
CWU Ellensburg, WA
Mar 9, 2007
  • Mar 9, 2007
I swapped in a Victor 5.0 for my old Typhoon last month, that thing is ****ing brutal let me tell you! It's a little soft until 2500rpm but then it really comes on hard. It also runs a lot cooler because it gets rid of the EGR system and has the "air gap" lower. I can run the engine hard as long as I want and the TB and upper will still be barely warm.
mricci
301
Massachusetts
Mar 9, 2007
  • Mar 9, 2007
here is a great write up on intakes. http://tmossporting.com/tabid/3451/Default.aspx
5.0vert
49
bethesda md
Mar 10, 2007
  • Mar 10, 2007
i have the bbk ssi intake its not as bad as everybody says i have it on my 347 and it made an improvment over the saleen intake i had on there its just a bitch to put on but runs great waitin to get the car tuned again b4 i can get sum new numbers
D
dtlionsfan
83
#10
  • Mar 10, 2007
  • #10
I got an exlorer off ebay for $150 like new.Great deal and flows near or at the gt40 level.
joeyd0730
130
queens, ny
Mar 10, 2007
#11
  • Mar 10, 2007
  • #11
i have a tfs track heat for sale if you interested, you can view it on the auction site. its like new
87fab
51
Dallas,Texas
Mar 10, 2007
#12
  • Mar 10, 2007
  • #12
I just installed a Cobra intake...I like it alot.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
