intake question
Jquintel said:
The Larger Plug should be the ACT Sensor, The other two if i remember correctly control the flap on the front of the air box... can anbody confirm this??
That sounds about right. The larger one for the ACT should have like a 3/8 pipe fitting for it to screw into. As for the other two:
1)Is a small diameter plastic line with a rubber elbow from the around the fender ( heads up to the fire wall I believe also) that plugs up on top of the air box.
2) The small vaccum line that comes from the front of the air box towards the radiator near the botton of the air box ( air flapper) and wraps back up on top and plugs to the first small vaccum line.
I hope this helps and that also its a newer 2.3L like a 90-93 model :)
