Intake Questions
  • Thread starter Thread starter HGFireHazard
  • Start date Start date Apr 12, 2005
HGFireHazard
460
Michigan
Apr 12, 2005
  • Apr 12, 2005
I've been searching around and want to get the basic bolt-ons out of the way this summer and save more extensive upgrade for the future. I'm confused about intake systems (such as the C&L) which come with a 73 or 76 mm MAF. What exactly is the purpose of the MAF? Further, would it be okay to get the MAC CAI, get a Pro-M MAF (76mm?) and a 65mm throttle body? If someone could clarify some of this basic stuff it would greatly be appreciated.
(I know the topic has been beaten, but I searched and didn't come up with very much help)
HGFireHazard
460
Michigan
Apr 12, 2005
  • Apr 12, 2005
I really could use this info guys, anything at all please.
NKau
1,346
Jefferson, WI
Apr 12, 2005
  • Apr 12, 2005
HGFireHazard said:
I'm confused about intake systems (such as the C&L) which come with a 73 or 76 mm MAF. What exactly is the purpose of the MAF? Further, would it be okay to get the MAC CAI, get a Pro-M MAF (76mm?) and a 65mm throttle body?QUOTE]
The stock MAF and TB become restrictive once aftermarket heads/cam/intake are added. Also, when running bigger injectors, you need a MAF calibrated for those injectors.
CAI's are a waste of money IMO; more for looks than power. And as far as upgrading the MAF and TB, I'd wait until you are ready to change your h/c/i. Remember that you will probably want to upgrade your fuel pump as well, and possibley add an adjustable regulator.
slytherin
702
northeast ohio
Apr 13, 2005
  • Apr 13, 2005
check out that new bbk ssi intake, and get a 70mm TB and a pro m 75 bullet maf
89roadster
1,124
Kent Island, MD
Apr 13, 2005
  • Apr 13, 2005
Agreed - the stock air cleaner with a K&N and the air silencer removed provides everything you need until you start adding much more power.
BTW Pro-M is out of business, but there is another company that is taking over where they left off (forget their name right now - do a search of the forums).
If you're on a budget, talk to Thumper460 and TMOSS about their ported stock heads and lower intake respectively. Then you will be much happier with MAFs and TBs when you get them.
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Idle spark confusion
  • sav22rem22
  • Oct 26, 2023
  • Digital Self-tuning Forum
2K
Digital Self-tuning Forum Nov 1, 2023
sav22rem22
302 Engine build questions
  • Vulpes5.0
  • Apr 19, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2022
LEEDAY Boss
