There is a kit, but unless you are running a power adder, expect to lose about 60 torque off the line. Running a delete kit is fine with a power adder since you will more than make it up, but its not worth the kit without a Power adder. The problem could also be that the IRMC plates need cleaning. The butterfly's may not be opening up. This is a common problem for all 96-98 4V engines. Try cleaning the plates first which fixes most problems, and if it doesnt then replace the controller unit (around $90). If it is just the plates causing the code, you will notice some additional power after 3250 rpms which is when the IMRC's should open up.
Good luck!!!!
