I have a GT40 Upper and lower intake, recently had to remove the upper and replace the space as it was wearing out from years of heat damage and minor cracking that was causing a vacum leak. I replaced it with a new BBK spacer, but now my throttle cable bracket will not fit back properly. I know I could cut the bracket as many people do, but I don't want to.
My old spacer was 3/4" thick, the new BBK is 3/8" thick. I have looked at cannot find a 3/4" spacer anywhere, but I see that Trick Flow makes one that is 1" thick. Will the 1" spacer fit under a stock hood? Anybody using the same setup? It was tight before with the 3/4" spacer. I also have the FRPP stamped aluminum valve covers, which are taller and why the bracket will not fit.
And one last thing someone gave me another 3/8" spacer for a GT 40 type intake, but it does not have a hole in the center like mine does. What is this off of, Cobra? I see some Cobra intakes with the center hole.
