  • SN95 4.6L Mustang Tech
Intake??? what do get?
  • Thread starter Thread starter PonyTrader
  • Start date Start date Aug 22, 2006
P
PonyTrader
14
Clearwater, FL
Aug 22, 2006
  • Aug 22, 2006
I used to have MAC cold air intake on my previous mustang..now on the new one i got i want to start doing some mods but i dont know if i want to go with MAC cold air intake again. I dont think i want to go with stainless steel again...it gets so HOT!!! and i dont know how it can help get cooler air in when its metal. I was thinking about something new? any suggestion? what do you think is the best?
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 22, 2006
  • Aug 22, 2006
i agree that that systems like MAC and Steeda(which i have) get pretty hot, a lot of people here will suggest keeping your stock plastic set up. It depends if your going to do serious modding IMO, in that case get a 80mm mass air w/ MAC or sumthing, then 70-75mm TB and plenum.
P.S. you could custom fab some plastic set up to the side air hole if u want, iv seen it done ill look for pics
d98gt
4,505
59
204
SE Texas
Aug 22, 2006
  • Aug 22, 2006
http://www.demolet.com/9604gtnew.htm
http://jlttruecoldair.com/zencart/index.php?main_page=product_info&cPath=1_9_22&products_id=79
It's pretty much a cosmetic mod so you should go with a painted JLT or Demolet
P
PonyTrader
14
Clearwater, FL
Aug 22, 2006
  • Aug 22, 2006
hmm..what exactly makes a MAC cold air intake be a performance upgrade. It doesnt seem like the air flow's diameter is any bigger then the stock intake.
nwapache
313
Seattle,WA
Aug 23, 2006
  • Aug 23, 2006
yada yada yada, just remove the air silencer and drop in a K&N issue solved...save the money for something that works like an intake plenum and tb
D
dannyboy1999
147
Crossville, TN
Aug 23, 2006
  • Aug 23, 2006
i see where your comming from with the pipe being made of metal and getting hot but this is what you got to look at. CAIs which stay in the engine bay are not true CAIs. Find one that fits in the fender well with a heat sheild. The trick is it sucks cold air as you drive not 300 degree air from your engine bay. The metal intakes also are smooth alowing air to flow more efficiently and quickly. It hits you TB quick enough that you pipe heating up really doenst heat the air that much. Even If it does you got to think your forceing air thats like 70 degrees up there even if it heated up its still alot cooler then the engine is and alot less restricted.
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Aug 23, 2006
  • Aug 23, 2006
I've heard a lot of issues can be caused by that bend for the CAI's that go in the fenderwell. But CAI's don't dramatically effect our cars anyways.. we dont gain 50 hp like civics do lol I went for what I thought looked nice, which is why I have a steeda intake.
D
dannyboy1999
147
Crossville, TN
Aug 23, 2006
  • Aug 23, 2006
UPR here
Hauuse96gt
46
Dayton, Ohio
Aug 24, 2006
  • Aug 24, 2006
I love my MAC it sounds good when I am out cruising around. Now don't get me wrong, I would change it in a heartbeat for the sound of a supercharger, but it will work for now.
Plus, when you lift your hood the MAC CAI is alot more impressive looking then the stock one.
the98stang
2,408
Clovis, CA
Aug 24, 2006
#10
  • Aug 24, 2006
  • #10
skip the intake, get some pullies instead. Or save that money for gears.
MY Cobra
308
Franklin NC
Aug 24, 2006
#11
  • Aug 24, 2006
  • #11
Go with JLT. I have had them before i have had bbk i have had mac. You will not beat the JLT. You need to take some things in to account when thinking about a CAI
1.) You want a CAI that does not have any 90 degree bends (it slows down the flow)
2.) You want one that brings the air from the fender (Colder air is better)
3.) You want a CAI that has a bigger diamater pipe so it pulls more air.
Think of it this way if you have a larger mass air meeter, Throttle body and all of that what is it feeding off of? The air that comes in threw a cheap piece of plastic that ford gives you with a filter in it.
Another thing to think about is if you want to spend the money and get something that looks good or something that works or if you even want to spend money. I would spend a little more and get the JLT that looks good and works great.
Just my .02 ~Nick~
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
01 GT NO IDLE
  • Scwhitten
  • Apr 15, 2025
SN95 4.6L Mustang Tech Apr 22, 2025
89ripper
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
