Intake
  • Thread starter Thread starter James S
  • Start date Start date Jul 10, 2026
J
James S
Michigan
Jul 10, 2026
  • Jul 10, 2026
Hi new to this forum. I have a question about what intakes to use. I am building a ford performance 347 for my 95 mustang gt . I would like to find the best intakes for the car,I want to keep standard throttle linkage and stay under the stock shock tower brace. So a little bit more information on the engine, I’m using an x303 cam, ford performance z2 heads and I will be using a Holley terminator x control to eliminate maf and make it speed density. Any tips.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jul 10, 2026
  • Jul 10, 2026
Use?
This a high RPM track/drag motor? Or a street build?
For long runner intakes there aren’t really a whole lot of choices left. Holley, trick flow or Edelbrock. I’d prob lean to the Holley myself.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Jul 10, 2026
  • Jul 10, 2026
I'm pretty sure the Holley Systemax 2 is still the best. I have to admit that I bought one 25 years ago and still have it. You will need an elbow to convert it to an SN throttle body, but those are cheap. The key to keeping the stock hood height is actually the valve covers regardless of which intake you choose. The Z2 heads use stud mount rockers which require more valve cover clearance. You need to find a set of the discontinued Trick Flow low profile valve covers. They are the only ones that clear stud mount rockers, the alternator on an SN, and do not require a phenolic spacer on the intake. Even with the Trick Flow valve covers, I had to grind a couple of mils off the upper plenum to clear the valve covers.
Kurt
Reactions: James S
J
James S
Michigan
Jul 11, 2026
  • Jul 11, 2026
Thanks for the advice. And I think it would mostly see street duty occasional track trips.
F
fasterthangas
290
92
38
Phoenix
Jul 11, 2026
  • Jul 11, 2026
Systemax or Edelbrock RPM ll.
Reactions: James S and AeroCoupe
J
James S
Michigan
Jul 11, 2026
  • Jul 11, 2026
From what I have read the shock tower brace may be a problem with clearance
F
fasterthangas
290
92
38
Phoenix
Jul 11, 2026
  • Jul 11, 2026
Didn't Maximum Motorsports make one that clears?
F
fasterthangas
290
92
38
Phoenix
Jul 11, 2026
  • Jul 11, 2026
If you could find one used...
F
fasterthangas
290
92
38
Phoenix
Jul 11, 2026
  • Jul 11, 2026
https://www.maximummotorsports.com/1994-95-Mustang-GT-Cobra-Strut-Tower-Brace-P596.aspx
RaggedGT
Mod Dude
Jul 20, 2014
4,766
3,224
203
Taylorsville ky
Jul 11, 2026
#10
  • Jul 11, 2026
  • #10
I agree with this one
I still miss @Davedacarpainter
Reactions: General karthief
J
James S
Michigan
Jul 12, 2026
#11
  • Jul 12, 2026
  • #11
I believe they do I have sent an email to them to find out. Thanks for your help.
J
SN95 Hello new to this app
  • James S
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Habu135
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
