  • SN95 4.6L Mustang Tech
Intercooler Question
  • Thread starter Thread starter swl987
  • Start date Start date Feb 5, 2009
swl987
200
Cleveland,Oh
Feb 5, 2009
  • Feb 5, 2009
I want to get a intercooler. I don't weld so I need a complete bolt on Kit. Is there any other kit out there besides the paxton that is bolt on. I know I will have to weld a bypass. With the paxton,a bypass, and a flange it's going to be near 1800 bucks. I see just intercoolers on modularpowerhouse for 400 bucks. So the paxton kit is a grand more for just some plumbing,hose clamps,bolts etc. There's got to be a better way. Also, does anybody know how much horsepower the paxton can handle.thanks
04YELLOWGT
1,135
Indiana
Feb 5, 2009
  • Feb 5, 2009
I have the paxton and its a great kit and was a sinch to install. I remeber talking to Tim at MPH and he said the Paxton IC was good for like 1000-1200hp.
the98stang
2,408
Clovis, CA
Feb 6, 2009
  • Feb 6, 2009
just buy a IC off ebay and make a DIY FMIC like I did
I see 90^ IAC @ 100 + ^ outside. That's 100% efficiency
notchnut
234
New England
Feb 6, 2009
  • Feb 6, 2009
I bought a 3" kit from CXRacing with all the 3"aluminum piping a t-bolt clamps for $250.00, call them first he will deal with you on shipping. I then bought a Vortech Mini race bypass valve USED on EBAY for $180.00. All in all thats pretty cheap for a pretty good quality FMIC. I will be converting to blow through so I have to buy a new MAF but then I'll be done. I hope
oxfordgt
288
Clarksville, TN
Feb 7, 2009
  • Feb 7, 2009
I am using a cx racing 4in intercooler set up. I had all my piping welded because I'm running 18lbs of boost. But you can bolt it all on and make it fit right. My IAT are at 78* with outside temp of 60* and drop to 58* when my meth starts to spray.
98stangv8
1,036
fayetteville, nc
Feb 7, 2009
  • Feb 7, 2009
Do you have a draw through setup now? If you put an intercooler on there...keep in mind you may need a new MAF and a new tune as well...it isn't just "bolt on an inctercooler" and drive...
swl987
200
Cleveland,Oh
Feb 10, 2009
  • Feb 10, 2009
Did you put your intercooler on after you had your blower, or did you put it on the same time? If after, how much of a difference was it? Were you impressed?
04YELLOWGT
1,135
Indiana
Feb 10, 2009
  • Feb 10, 2009
After the blower.
I pullied down while adding the IC like most people do. There was a definate gain in power. I don't remember what I picked up on the dyno but I remember going OMG while getting on it for the first time after the retune.
98stangv8
1,036
fayetteville, nc
Feb 10, 2009
  • Feb 10, 2009
04YELLOWGT said:
After the blower.
Did you have to change to a blow through setup? Did you need a retune?
04YELLOWGT
1,135
Indiana
Feb 11, 2009
#10
  • Feb 11, 2009
  • #10
No you don't have to change to a blow-through, but you do need to upgrade your BPV if its the stock Bosch one the Vortech kit comes with.
I got a retune just to take full advantage of the IC and smaller pulley and I would reccomend at least checking you AFR if you pulley down with the IC.
swl987
200
Cleveland,Oh
Feb 11, 2009
#11
  • Feb 11, 2009
  • #11
04YELLOWGT said:
After the blower.
Thank you Mr. Yellow.I'm sold. Which pulley size did you get? What is a blow through setup?
04YELLOWGT
1,135
Indiana
Feb 11, 2009
#12
  • Feb 11, 2009
  • #12
I don't remeber what size pulley I went to. Just call Tim at MPH and he can set you up with everything you need.
A blow through setup is a different different setup for you MAF. If you run that you usually run a BOV instead of a BPV. Prochargers use the blow through setup for some reason.
oxfordgt
288
Clarksville, TN
Feb 12, 2009
#13
  • Feb 12, 2009
  • #13
Blow thru is better for driveability. It is a bit more trouble to tune but more acurate of a reading.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
C
Paxton novi 1200SL
  • Cambo617
  • Oct 9, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 9, 2025
Cambo617
C
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
