Interesting Problem
rsev216,
Good find!:nice: The first time I had an 1157 buld go shorted on me, it had the same symptoms as you had with the additional issues of my right turn signal making the dash lights and all parking lights flash on and off AND when the dash lights were properly on, with the headlight switch, it dimmly lit the turn signal indicator lights.:eek: At the time, I thought my wiring harness was pooched and was thrilled to find a bad/shorted bulb. I cleaned all sockets and replaced all 1157's, problem cured.:D
Congrats,
Gene
Problem solved! The wiring harness connector that slides over the bulb housing was not making good contact thus creating a high resistance ground. This resulted in current bleeding through the other filaments in the 1157 bulb and turning on the dash lights.
