interior painting help
  • Thread starter Thread starter TK_05
  • Start date Start date Jan 5, 2004
TK_05
286
Las Vegas
Jan 5, 2004
  • Jan 5, 2004
well i went out and bought some vinyl paint from checkers... i spent all week looking for vinyle dye but i cant find it... anyway i got the stuff from checkers and it looks good but it scratches off pretty easily... i was wondering where i can get vinyl dye... anyone know?
hllon4whls
BANNED
2,567
Covington
Jan 5, 2004
  • Jan 5, 2004
www.50resto.com
I painted my interior with red devil enamel satin paint. Came out great. You have to degrease like crazy to all the painting parts before you paint. If not it wont stick.
Also lookinto krylon plastic fusion paint.
1986LX2002
317
  • Jan 6, 2004
I have an 86 Gt i'm restoring bascially right now. The car used to have Red interior but I changed over too SVO gray or "charcoal gray". Anyway i bought some cans from 50resto and the color is off just a little. You can tell my dash is lighter than my new Door panels I picked off an 86 SVO. SO!! What i did is i went down to my local paint shop in PHX here "spaceage paint and supply" and they gave me the exact color i needed, and now it matches pertfectly. You cant tell I even sprayed them. Heres what i did, clean the panels totally! for a awesome turn out! Use some plastic adhension promoter "that way the paint you spray sticks, you only need some light coats" Then i just poured the paint into my spray gun and shot it. The paint shop I goto can also put the paint into rattle cans but they said that i'll have to use manys coats to achieve the right color. And since i wanted to get done i just used my gun. I'll post some pics as soon as the car gets the 3rd tranny installed!! OH and i used a SATIN clear coat to top it off. And i cant scratch any of my paint off either. Its as if it came from the factory. I've rubbed a panel for about 30min with Finish 2000 spray and nothing rubbed off so im' happy.
C
cmclean
243
Houston, TX
Jan 6, 2004
  • Jan 6, 2004
I used Duplicolor Vinyl spray. I believe the spray from www.50resto.com is basically the same stuff, paint. Prep is the key. I'm happy with my black interior. Make sure you let it dry for a good 24 hours before handling it alot.
Whytry91
321
Morrisville, NC
Jan 6, 2004
  • Jan 6, 2004
Walmart sells it
TK_05
286
Las Vegas
Jan 6, 2004
  • Jan 6, 2004
i sprayed it w/ an ass load of thin coats but when i went to install the instrument bezel it just chipped off... i didnt allow it to sit for 24 hours but i went out there today and it scratched off just as easy as it did before??? and it LOOKS AWESOME! just scrathches to easy...
V
v8only
2,378
22
49
Jan 6, 2004
  • Jan 6, 2004
Get used to the scratching and flaking, that's just a normal part of it. That is why it is best to only paint in low traffic areas, areas that won't get touched too often.
IMO, it is always best to use original color parts. I have experimented with a flat color, and sprayed a clear coat over it, which gives it a semi gloss finish, much more durable, and highly resistant to chipping, but still not foolproof.
R
rseifert
200
Lung Gyland, NY
Jan 6, 2004
  • Jan 6, 2004
Be sure to clean the plastic really well before painting it, if there is any trace of Armorall on it at all it will not stick. I used the stuff from 50resto. Just apply many coats. It shouldnt flake off like that. Use accetone or something strong like that to prep to be sure. Have fun
TK_05
286
Las Vegas
Jan 6, 2004
  • Jan 6, 2004
i was using flat black.. looked good.. i dont want that glossy stuff... and yes i was using acetone to paint... i was also painting w/ that duplicolor vinyle paint.. guess ill just add more layers until its idiot proof or something
Paint and Body Dying interior quarter panels, can you color change?
  • AnthonyA1234
  • Aug 26, 2024
Fox 5.0 Mustang Tech Aug 28, 2024
limp
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
Interior and Upholstery Best vinyl adhesive for door panels?
  • wobbyguy
  • Jan 27, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 31, 2025
limp
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
