Intermit Stutering losing spark
mapoff
Blacksburg, VA
Help I'm going to pull the trigger.
Out of the blue the car started stuttering as if more than 1 cyclinder was not getting spark intermit. all driving ranges. i replaced the coil. no go, checked power going to the coil and it randomly drops out at the same time it stutters.
could a loose timing chain be the cause. isn't there a "hall effect" sensor that tells the computer when each cyclinder is tdc which. the ground on the battery was slightly loose, i tightened that and didn't notice it for a day. next day same thing. i have new
cap
rotor
plugs
plug wires
coil
air filter
ignition module
Yeah, the PIP inside the dizzy has been known to cause sputtering, no-start conditions (including the one I'm troubleshooting on my '88 currently.)
By ignition module I don't know if you mean the TFI, or the ignition switch, but the TFI module also has been known to overheat and cause stuttering, etc.
As Andy said, the PIP is very possible.
Down and dirty test: put your inductive timing light on each plug wire and hit the trigger. Note any cylinders which dont have a constant nice spark (indicated via the timing light pulse).
A cylinder balance test could be very revealing if you can run tests while the car is hiccup-ing.
Good luck.
Pip?
Well you can only tell when your going down the road, hot and cold, high and low rpms. i did replace the thick film module. i do not know what a pip is.
another piece of info, when it goes out the pwr to the coil goes out, and more than 1 cyclinder in a row misses. it all happened immediately. something is def going down electronically. i hate stupid problems like this that aren't in your face.
The pip is the sensor is in the bottom of the distributor that triggers the TFI. You have to press the gear off the distributor shaft to get access to it to replace it. Most guys just end up replacing the distributor with a reman unit for about $75 exchange
I have already bought the part from way back for some reason but never put it on. does the distributor just pull right out, after i make a mark of where it was? all it is, is a shaft with the stuff on top. would there be any other advantage of replacing the whole thing vs me replacing that pip.
plus is it worth the hassle if i'm not sure thats it, or just take it somewhere to be looked at. i'm just sick of spending so much money and time and nothing going anywhere
