Help I'm going to pull the trigger.
Out of the blue the car started stuttering as if more than 1 cyclinder was not getting spark intermit. all driving ranges. i replaced the coil. no go, checked power going to the coil and it randomly drops out at the same time it stutters.
could a loose timing chain be the cause. isn't there a "hall effect" sensor that tells the computer when each cyclinder is tdc which. the ground on the battery was slightly loose, i tightened that and didn't notice it for a day. next day same thing. i have new
cap
rotor
plugs
plug wires
coil
air filter
ignition module
cap
rotor
plugs
plug wires
coil
air filter
ignition module
