  • 1994 - 1995 Specific Tech
intermitent check engine light
  • Thread starter Thread starter Highoutput5.0
  • Start date Start date Jan 18, 2006
Highoutput5.0
17
RI
Jan 18, 2006
  • Jan 18, 2006
i have a 94 and the check engine light comes one only after moderate to hard acceleration and stays on for about 20 seconds then turns off...less than 20 if accel wasnt hard, more after hard accel...any thoughts will be helpfull..thanks...i have had the obd 2 scanner hooked up while driving but it can never pick up the code before the Check light turns off
MysteryMachine
1,835
Parkesburg, PA
Jan 18, 2006
  • Jan 18, 2006
Our cars use a obd 1 scanner. It plugs in under the hood. Mine does that for insuffecent egr flow might be your problem
R.J.
813
Warwick, Rhode Island
Jan 18, 2006
  • Jan 18, 2006
Same here with insuffecent egr flow. I pulled the codes and got that specific code. I forget the number. I put a vac pump on my egr and it moved fine so I pulled it off and cleaned it and he intakewhere it bolts on. The check engine light has not come back on.
bill302
2,131
alabama,gadsden
Jan 18, 2006
  • Jan 18, 2006
obd 2 scanner is the wrong scanner if yours is like mine the plug in under dash will allow a obd 2 to hookup but i believe its a dummy plugin a ford thing i don't know. but your system is a obd 1 unless you have installed a 4.6 or 3.8. even if light is not illuminated you can retrieve codes at plugin on passenger side fender under hood about 5 inches forward of firewall it will be incased in a plastic case fastened to passenger side fender. drive car to autozone have them retrieve codes from this plugin or do it yourself with a test light click on link below. then post codes and get some replys from these guys you can throw 2-3or 4 codes sometimes (i was throwing 5 i reset t.p.s. and replaced cos2 sensor and cleared all 5) and only one sensor will need cleaning or replaced,believe me these guys will save you money good luck and welcome to stangnet.
MysteryMachine
1,835
Parkesburg, PA
Jan 18, 2006
  • Jan 18, 2006
332 lol i know it cause it shows up like every damn day. Mines cause them plastic vac lins broke and i have them rigged together
fiveotony
1,437
Gainesville, Ga
Jan 18, 2006
  • Jan 18, 2006
could be maybe an O2 sensor as well
HISSIN50
34
129
Jan 19, 2006
  • Jan 19, 2006
Welcome to the boards! As mentioned, the 94-95 GT's are OBD-I and the 6 cylinder models were OBD-II (hence why there are both plugs).
Good luck.
Highoutput5.0
17
RI
Jan 19, 2006
  • Jan 19, 2006
so can you read any codes with the obd 2 scanner on 1994 models?
HISSIN50
34
129
Jan 19, 2006
  • Jan 19, 2006
Sure, if you have a V6.
95cobraguy
637
11
Concord, NC by way of LI, NY
Jan 19, 2006
#10
  • Jan 19, 2006
  • #10
u need to find out if there are any trouble codes stored in the computer, until then nobody will have an answer to your problem.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
