Engine intermitent problem with stalling and torque converter locking up
car works fine 90% of the time . But sometimes when starting it up it won't idle. If you hold throttle open with your foot after a few minutes the rpms will speed up and it will idle normally. Also it will act up after driving for a while and torque converter will lock up and transmission shifts hard. The volt meter shows a large draw on it when this happens have been to Ford and several other mechanics ut none have been able to help.
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :D
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 250,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
