I am having an occasional problem with my 93 Stang not wanting to crank. It is 5 speed and I've replaced the saftey switch attached to the clutch pedal that prevents the car from starting unless the pedal is depressed. However, the problem is still present.
Typically what happens is I'll try to start the car but nothing happens. No click, no engine turn over, not anything (I do hear the fuel pump run, the dash lights come on, etc). Usually I'll depress the clutch pedal a few times while turning the ignition key and eventually it will fire up. Very frustrating, especially when you are in a hurry.
Do you all have any ideas of what else I can check?
