intermittant cranking problems
I am having an occasional problem with my 93 Stang not wanting to crank. It is 5 speed and I've replaced the saftey switch attached to the clutch pedal that prevents the car from starting unless the pedal is depressed. However, the problem is still present.
Typically what happens is I'll try to start the car but nothing happens. No click, no engine turn over, not anything (I do hear the fuel pump run, the dash lights come on, etc). Usually I'll depress the clutch pedal a few times while turning the ignition key and eventually it will fire up. Very frustrating, especially when you are in a hurry.
Do you all have any ideas of what else I can check?
Yes, check to see if your selinoid is collapsing. The function of the coil within the selinoid has the sole function of firing the starter then releasing.
Ryan
You look for 12 volts at the S-terminal.
You can check for 12 volts at the clutch safety switch while cranking (and having the switch closed). Or just go to the ignition switch and check it there (the source).
Good luck.
Well, you can have someone crank the motor and check the voltage output at the starter post on the selinoid or you can check it at the starter.
You can also listen for the collapsing sound (it will clunk lightly).
While you are at it, just because you've replaced the clutch safety switch doesn't mean it it working, so check that as well by depressing the trigger and checking for continuity between posts.
Ryan
hivolt5.0 said:
You are referring the starter selinoid on fender correct? Forgive me ignorance here, but how would I check to see if it is collasping?
