  • SN95 4.6L Mustang Tech
internals with KB 9psi??
  • Thread starter Thread starter Dr. Black
  • Start date Start date Apr 8, 2005
Dr. Black
105
Henderson, Nevada
Apr 8, 2005
  • Apr 8, 2005
I'm going to be purchasing the 9psi kb for my ride. Since I'm putting that investment into the sc, what type of upgrade should I do for the internals. I know some who have the same kit do nothing, and it's not like I'm going to be beating the crap out of the thing. It has around 55,000 miles and I'm thinking of just being a little cautious. I don't forsee ever wanting more than 425-450rwhp. So what does everyone recomend?
Thanks
sgarlic
3,085
Apr 8, 2005
  • Apr 8, 2005
If you're going to upgrade the lower end.. you might as well do everything while you have it apart.. pistons, rods, oil pump gears, port&polish, etc. Up to you. If you have the time/money.. definately worth it from what I hear.
2000silverbulit
31
Dublin/Walnut Creek, CA
Apr 9, 2005
  • Apr 9, 2005
forged internals more than anything else...and YA sure you are just going to stick with 425...i dont think so..MORE POWER!!!! LOL
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Apr 9, 2005
  • Apr 9, 2005
Amen, if you've got the dough for the s/c, you can save a little more, or spend a little more depending on your situation and go for strenthening the engine's internals. Better safe than sorry.
02mingreyconv
127
Bartlett, IL
Apr 9, 2005
  • Apr 9, 2005
Thanks
Forge the internals. I didn't and now I regret it. I just had a custom tune done and I noiw put down 417/434 and I still crave more. Don't think that you will ever be satisfied. I could run 11 psi on pump gas with a good tune, which would probably be 450 rwhp but right now I do not dare to go over the 9 psi that I am running.
Heck, I'd even recommend to get forged and get the bigger blower (2.2) bc I now know that you can never have enough HP. It will be a challenge to get all the power on the ground, but thats just fun.
jmk97GT
178
  • Apr 9, 2005
With all these upgrades what is a safe psi for the 1.7L?
Dr. Black
105
Henderson, Nevada
Apr 9, 2005
  • Apr 9, 2005
So 425 not enough....yah..who am I kidding, I'm sure I'll want more...who doesn't. Cost wise (for the parts) what am I looking at for the forged internals, and who would be a good source of products?
Thanks for all your input!!!
kevs_roush360R
41
Euless, Texas
Apr 9, 2005
  • Apr 9, 2005
Check out Sean Hyland,
http://www.seanhylandmotorsport.com/online/product_info.php?cPath=65&products_id=1170
"4.6 Rotating Assembly - Engine Building Special From $1,495.00
Full rotating assembly kit for 4.6 engines including Manley forged pistons and H-beam rods, forged steel crankshaft, SHM moly piston rings, Clevite rod bearings, and Federal Mogul main bearings. The quality doesn’t get better than this for aggressive street or moderate race applications up to 650 hp, 7000 rpm. "
When I bought my 360R I thought the same thing - that I wouldn't crave anymore power...wrong! Trust me, it doesn't take long to get used to more power (just wait 'til you get beat in a race with all that new power...then it's not enough).
Check out Kenne Bell's FAQs and Tech Tips - they have LOTS of good info on power levels and reliability.
If you can live with 400-430 rwhp in a "everything included and tuned" kit then the 1.7L (9psi - intercooled) kit is where you want to go. Obviously, you can only push so much boost with the 1.7L before you're operating out of the efficiency range for that blower. If you want 500+ rwhp, go with the blowzilla (2.2L)
Dr. Black
105
Henderson, Nevada
Apr 9, 2005
  • Apr 9, 2005
Thanks That's exactly what I was looking for!!!
GitDat
529
Indy
Apr 10, 2005
#10
  • Apr 10, 2005
  • #10
Why forge.. just live on the edge like me *BOOM*
00s281sc368
532
Fremont, CA
Apr 10, 2005
#11
  • Apr 10, 2005
  • #11
I've run my 9psi KB for 1 and 1/2 year now on stock internals without any problems. And if you look at my numbers, i'm quite happy
GitDat
529
Indy
Apr 10, 2005
#12
  • Apr 10, 2005
  • #12
Does anyone with the 9psi pulley see their boost go over 9psi in the higher RPMs? I have the 10psi pulley and by 6000RPMs my boost guage is reading 13psi
00s281sc368
532
Fremont, CA
Apr 11, 2005
#13
  • Apr 11, 2005
  • #13
Actually I read 10 to 11psi on my saleen boost gauge, although I have the 9psi kit.
I see 10psi from 2000rpm....
GitDat
529
Indy
Apr 11, 2005
#14
  • Apr 11, 2005
  • #14
So you see a straight 10-11psi through to redline? It doesn't build slightly more as you stay on it? Mine hits 10psi instantly down low but builds to 13 fairly quickly and stays there until 6000RPM.
U
USMC_MuSTaNG
82
south carolina
Apr 11, 2005
#15
  • Apr 11, 2005
  • #15
Make sure your intercooler pump is working. Mine lost it's prime and i saw that kinda boost. Soon as I primed it again it was back to around 10PSI at WOT
GitDat
529
Indy
Apr 11, 2005
#16
  • Apr 11, 2005
  • #16
I remember reading something about priming the intercooler pump being a pain but I didn't do the install. So how do I check this? lol
U
USMC_MuSTaNG
82
south carolina
Apr 12, 2005
#17
  • Apr 12, 2005
  • #17
just turn your key but don't start it. You should hear the pump making a whuring sound. If it is gurgling...it has lost it's prime.
P
prsrizdgt
231
St. Louis
Apr 12, 2005
#18
  • Apr 12, 2005
  • #18
You guys don't forget that boost is a measurement of restriction. You are pumping a rather large volume of air with the KB screw blower into a motor with stock cams, stock heads (although good ones), and stock manifolds it appears, and catted midpipes. I also showed higher than rated boost until I went to aftermarket cams and offroad pipe (which is now for sale ). Now it reads 8.5 - 9 psi like it should.
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
N
New Edge 3.8L Forged Internals
  • NtheGAME
  • Jun 1, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 3, 2025
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
