Irritating noise
Silver Fox 90
:shrug: Ok here it goes, I have a squeel in the engine area and I couldnt locate for a long time so I threw money at it and it didnt get better:rlaugh: Ive changed the Alt. ,power steering pump and the a/c clutch ass. Well it seemed to get better I thought after the A/c clutch swap on Thursday but i was wrong. I got on her today and it still squeeled:bs: .... Oh yeah im new here thanks....... its on the Fox
Yep I third the belt slippage, especially if your saying you got on it when it happened. You can try a few things, Check your belt for excessive wear( if you have a manual you can check the tensioner for tolerance) Also if its over 20-30k and you live in a rainy/snowy climate they tend to die sooner. They are cheap insurance I keep a few in the trunk. (well... wheel well)
Good Luck with your squel
Yes the belt is correct, and every thing is aligned properly. It happened the same day I had the gears put in. Im sure now that it is the tensioner pulley. Thanks guys for the advice and will post pictures of boyh stangs soon.
Silver Fox
