IRS in a 67 fastback ??
  • Thread starter Thread starter SLVRBOY
  • Start date Start date Apr 8, 2005
SLVRBOY
91
st. augustine , fl.
Apr 8, 2005
  • Apr 8, 2005
i am thinking about putting an IRS out of a newer cobra in my car but
im not sure if its worth the trouble to install or if i will get enough
performance out of it compared to a good 3-link setup wit a solid axle.
price is a concern also. i already have the stock v8 rearend and an 8.8
out of a 91 gt that i could use. unless the 9'' is just the way to go.
rhyno9
209
Oswego Illinnoying
Apr 8, 2005
  • Apr 8, 2005
It really depends on how you will use the car. Drag racing I would go with the 9 or the 8.8 is quite strong as well. The 8 inch is just for cruising with less than 350 hp and the IRS has some wow factor but it will shine on the road course. For install information on the 03 IRS in a early mustang go to
www.dvsrestorations.com
reenmachine
20+ Year Stangneter
Jun 27, 2004
1,258
Montrose, CA
Apr 8, 2005
  • Apr 8, 2005
I'm ramping up to do this swap in my '67 Fastback test car and in a customer's car as well. I'll post pics when I get underway. Where are you located?
Edbert
3,548
32
109
Austin TX
Apr 8, 2005
  • Apr 8, 2005
Talk to Dave at DVS like Rhyno said, he's a great guy and will give you all the info/parts you need.
SLVRBOY
91
st. augustine , fl.
Apr 8, 2005
  • Apr 8, 2005
im in st. augustine , fl.
i know you have to flare the wheel wells
because the irs is a little wider.
i have a 331 stroker with trick flow heads
and an air gap intake but no cam or carb. yet.
i havent seen many old mustangs around here that arent original or close to it.
so some pics. would be great
bnickel
5,640
lubbock, texas
Apr 8, 2005
  • Apr 8, 2005
actually on the 67 you won't have to flare the fenders, you might have to roll the fender lips on the inside but not flare them. if you had a 65-66 then you would have to flare them as they are quite a bit narrower than the later cars
Soaring1
Banned
Jan 3, 2003
144
Texas
Apr 8, 2005
  • Apr 8, 2005
That 8 incher wiil take more than you give it credit.
J
What's it Worth? Cobra IRS
  • johnnyj331
  • Aug 25, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Aug 25, 2025
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
