I wanted to know if all of you that have an alum driveshaft if you noticed any extra driveline noise after installing it.
I have completely rebuilt my rear in the car with 4.10s, Eaton, Megabite Lwr Ctrl arms, and Steeda adj uppers. While I was doing all of this I added a FMS aluminum driveshaft. Now I know I did a lot a once, but I am getting a lot of added transmission noise. I have a feeling it is due to the alum drivesshaft. Just as a note I still need to check the pinion angle, but I set the upper arms to stock length when installing them.
The problem is that when shifting gears I get a noticable clunk type noise in the driveline both when entering and leaving a gear. Also, the rattling noise of the trans when in nuetral is also much more noticable. I am 99% sure the gears are right since I have no whining problems and I checked the spec like 10 times.
Does an aluminum driveshaft AMPLIFY driveline noises?
I will try swapping the stock one back in to see if it makes any difference. Also, did you remove the weight on the axle when you installed your alum driveshaft. I did, and was wondering if I should reinstall it.
Thanks
Thanks
