Is a fox intake swap worth it?
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
My cousin wants to swap a fox style intake manifolds onto his 95 GT. This intake has been ported and comes with a spacer. I'm thinking the extra 10HP (if that) isn't worth all this trouble, unless a ported fox body intake setup is a lot better than the stock 95 intakes? How hard would it be to swap these things? Would he need the elbow for the TB?
thanks
the big restriction with the stock intakes is the lower, is that also ported or just the upper? if he also swapped to a fox style TB then he would not need an elbow, but if he wanted to keep the 94/95 style then he would need an elbow
If he's going to keep the fox style throttle body on the intake than he will pick up some throttle response too, but theres more to the swap than just putting the fox pieces on. He has to swap the throttle cable, cruise control cable,CAI,throttle position sensor, and the IAC from the fox body to make it work.
