For dragstrip, is a rev limiter absolutely necessary? And technically how do they work? I don't see how they can limit your RPMs with the clutch disengaged and the pedal to the metal during powershifting.
iskwezm said:i have the MSD Digital 6 and wouldnt run with out it,plus it has a 2 step, so when you want to launch, set the rpm to say 4500 RPM, lights start to come down,push the button(also works my line lock)you nail the gas and it will "bounce" at 4500,bam release clutch,the 2nd rev limiter will limit the max rpm you want, mines at 7500, but with the blower im gonna lower it to 6300.Plus the Digi6 has a start retard, so its easier to start and a boost retard so if yoiu run NOS,it will retard 2,4* when activated.
same setup im running and i love it. well worth the money. if you run nos and it is only on a wot switch jacobs makes a nos controller that can close the nos solonoid when rpm limter comes on. it also has a rpm controller on it so nos only comes on at certain rpm or even gradually puts more nos on through rpm band.iskwezm said:i have the MSD Digital 6 and wouldnt run with out it,plus it has a 2 step, so when you want to launch, set the rpm to say 4500 RPM, lights start to come down,push the button(also works my line lock)you nail the gas and it will "bounce" at 4500,bam release clutch,the 2nd rev limiter will limit the max rpm you want, mines at 7500, but with the blower im gonna lower it to 6300.Plus the Digi6 has a start retard, so its easier to start and a boost retard so if yoiu run NOS,it will retard 2,4* when activated.
I would like to keep it simple but also prefer one as you mentioned that limits every other spark rather than giving nothing. What MSD models do this?limey66 said:...The better ones drop every other spark, progressively to give a softer limit rather than a load of nothing...
the digital 6 does, i like it because is doesnt use "chips" to set rpm limiters, the older ones, the 6 series (a,al,t) use "chips you have to buy and plug in and are the dinosours of the line.Cannoball888 said:I would like to keep it simple but also prefer one as you mentioned that limits every other spark rather than giving nothing. What MSD models do this?
