Is a T-Rex pump really needed?
KasperG
38
If you replace your main fuel pump with a 255 unit; are you still in the need of a t-rex. Assuming you are running a Vortech or any other supercharger. This might be a dumb question, but I think that a 255 per hour pump should provide enough fuel. Please prove me right or wrong:shrug:
yeah, i was actually told at my tuner that i should get an inline pump in addition to my 255 hp. I guess its a good idea, but i dont know the specific horsepower that a 255 can support, if i actually need one. Same question as you i guess lol.
It's my understanding that the T-rex is actually a restriction if you have the 255, because it's only a 190. I'm hoping that someone that really knows will chime in, because I HAVE a T-Rex and a 255 in-tank.....
41. Can I use a 190 liter per hour fuel pump by itself and eliminate the T-Rex?
It is not suggested that the 190 LPH fuel pump be used without the T-Rex fuel pump. The biggest single contributing factor to engine damage is inadequate fuel delivery. Supercharged applications should have excess capacity rather than inadequate capacity as the damage that can be incurred is far more expensive to repair than the cost of the fuel pump.
I Got this off the vortech website.... so i quess that if they are not sure that a 190 would supply it, then a 255 should be fine.:SNSign:
I have a 255 and a 190 and when I had my last tune at HPP Manny told me that I needed more fuel and suggested that I go with a Waldon pump,but it will have alot to do with your engine combo.
I actually just got back from the dyno today. With my combo I made 325/348 and I was on the verge of going lean almost every pull at the top end. I only have a 255 in tank. If that gives you any idea of what is required. They finally got it to a safe air fuel on the last pull.
Are you still using stock tb, cam, & heads?
If so, I would think with the 255 pump and 42's, you would not be working that fuel system so hard to go lean like that.
Was your fuel pressure really elevated?
Think your fuel filter might have some kind of issue that may be causing a restriction?
Not sure why ...... but that just don't seem right to me :shrug:
Grady
Grady
Yep, Stock Heads, Cam, Throttle body...
Fuel pressure is like 36 with the vacuum line off I believe...I forget what they told me they left it at...34 or 36. The fuel filter is only a year old so I wouldnt think its really that bad, I could be wrong though.:shrug:
