Is it ok to put a 94/95 MAF in the fender
  • Thread starter Thread starter mob
  • Start date Start date Mar 9, 2009
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 9, 2009
  • Mar 9, 2009
Hey guys, I ordered an Anderson Powerpipe today, the one that puts the MAf in the fender. I talked to the guy and he said that they dont recommend using anything other than the pro-m shorty because some MAF's like the c&l go crazy when you put them in the fender. I just want to make sure that I can use my 94/95 in the fender and not have any problems, he didn't know if I could or not. Is it going to matter which way the sensor is facing? Towards the fender or towards the wheel? Thanks
Nick
fords2fast4u
1,426
Mission Viejo, CA
Mar 9, 2009
  • Mar 9, 2009
The 94/95's have the 4 bolt mounting plate yes? Not sure how you're puttig that in the fenderwel, but when i first read your question about which way it should face, i thought you meant which way for the sensor to face to take in air... ha.
I had a pro-m in the driver's fender of my 95, no problems - but that's not what you're talking about here (as stated pro-m's np in the fender).
a stock 94/95 meter - you're only moving it about 8-10 inches, i wouldn't think there'd be any issues. For that I wouldn't even think that you'd have to splice any wires...
hopefully someone can chime in who's done something closer to what you're proposing.
vristang
4,933
101
124
Seattle
Mar 9, 2009
  • Mar 9, 2009
If it causes an issue it will likely be because of sharp bends just before and after the meter, which causes uneven flow across the sensor elements.
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 10, 2009
  • Mar 10, 2009
hm well I'll let you guys know how it works out in the next couple days when it goes in. Cenok has one in his fender and reports no problems so we'll see. Any more input would be good. Thanks!
Nick
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 10, 2009
  • Mar 10, 2009
oh and I was talking about which way the sensor can face to take the air in but I looked at the sensor and relize that's a dumb question haha
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 10, 2009
  • Mar 10, 2009
Well the guy from anderson said that the MAF isnt sensitive enough to be that far away from the throttle body. Any input on this?
vristang
4,933
101
124
Seattle
Mar 10, 2009
  • Mar 10, 2009
If you don't trust "the guy from anderson" then why bother asking him?
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 11, 2009
  • Mar 11, 2009
Its not that I dont trust him. Its that "cenok is family" has a custom power pipe that is exactly like the Anderson pipe, and is using the 95 GT MAF and hasent had a problem. I am going to try it out when I get my pipe in but I wondering if anyone has input on these different answers. I have an answer from someone who is using it saying it works, and one from the Anderson Tech guy saying it wont work.
cenok is family
1,409
69
79
Norman, Ok
Mar 11, 2009
  • Mar 11, 2009
i don't want to say it will most definitely work fine on your car. like i said with mine, it seems to be working fine, but i haven't verified where my a/f is at. it idles well and pulls like a raped ape though, so that's a good sign. i can smell gas so it might be running rich. nothing i can't fix though. the past two times i had it on a dyno, my a/f was at 10.x:1, but both times i had 24 lb injectors and a 75mm proflow (old pro-m) mass air meter. also on the first session i had a bbk cold air kit, the second time i had the factory intake tube and airbox with a drop in k&n. i'm pretty sure that maf sensor was bad though, i bought it used off ebay. my current sn95 maf i bought re-manufactured from autozone. i pulled it out of the box and it was an original ford housing with ford electronics on it too!
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Mar 11, 2009
#10
  • Mar 11, 2009
  • #10
I have my stock 96 Cobra MAF in my fender/bumper area and it's been that way for 5 years.
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Engine EGR spacer for explorer 65mm TB?
  • 91GTstroked
  • Dec 31, 2024
Fox 5.0 Mustang Tech Dec 31, 2024
