I am fixing an oil leak on a car I bought about 1 month ago and while I was doing the bolting down the bolts to 25 ft lbs one of the bolts snapped so I had to pull it back off and while I was doing that I leaned over the distributor hole and seen that the think that the distributor sits on looks broken, and was wondering if it would hurt the car to run like that? Here are some pics to help explain what I saw.
You have that motor apart and putting it back together and your not sure if that looks correct....
First off that "hole" is not any part of the dizzy. The oil pump is driven by the shaft at the end of the dizzy. This shaft goes into the engine block through "this hole" so it can meet the oil pump drive shaft. Sorry but im just concerned about the poor motor. I will help though with what I can, what are your plans having it apart like that??
