Is It Worth It?
  • Thread starter Thread starter rangerboy101
  • Start date Start date Sep 6, 2012
First Prev 2 of 2
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
Sep 9, 2012
#21
  • Sep 9, 2012
  • #21
If i remember correctly the shift point for those anderson cams is 6000rpm+.
Probably not optimal for your heads.
You're overthinking this cam thing, if this were a high end custom setup, i'd be all for trying to squeeze every last hp out of it, but it's not.
Use the E or the stage 1.
Reactions: 88LX5.Oh
rangerboy101
310
20
28
Inwood, WV
Sep 9, 2012
#22
  • Sep 9, 2012
  • #22
Haha I'm trying to not over think it. I guess I'm just trying to make the right decision ahead of time.
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Sep 9, 2012
#23
  • Sep 9, 2012
  • #23
No, the N41 is designed for 1.6's and the N21 is designed for 1.7's. The Anderson cam is a good choice. Yes, it is designed to be shifted around 6200 RPM. It is not designed to make max power at 6200 RPM. That would fall somewhere in the 5000+ range. The idea behind their suggested shift point is to keep your RPM's in the power making range when you go to the next gear. Shift at 6200, fall to 4400, still in good power making range (these are just examples, obviously depends on your gearing). The N41 and the N21 were designed with Gt40 heads in mind. The reason the N21 is designed for 1.7rr is because the stock Cobras came with them. The N21 was designed as a cam for stock headed Cobras with some mild mods.
I ran the TFS 1 up until recently, it is a good cam. Makes power up to around 5500RPM. I just recently swapped in the N41, not that noticable of a difference in the drivability market. Can't go wrong either way, but the TFS 1 cam can be picked up much cheaper, especially used.
Joe
rangerboy101
310
20
28
Inwood, WV
Sep 10, 2012
#24
  • Sep 10, 2012
  • #24
Price isn't the factor here. I'm really leaning towards the Anderson cam instead of the TFS
rangerboy101
310
20
28
Inwood, WV
Sep 10, 2012
#25
  • Sep 10, 2012
  • #25
Anderson N-412? Lol it's either that one, or just say hell with it and buy the TFS Stage 1 and call it a day. Thoughts?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 10, 2012
#26
  • Sep 10, 2012
  • #26
You seem awfully intent on buying an agressive cam (with price not being a factor) for a guy who hasn't once talked about upgrading those puny GT40 iron heads. If money isn't an issue, why not pick up a set of nice used aluminum castings and a used (and much cheaper) previously noted E-Cam or TFS1 that some have suggested. You'll make a whoooollllle lot more power with that, than just cam alone. And you'll knock 50lbs off the front end to boot?
I mean....you're already going to be more than half way to a head swap anyway. Why stop at the cam? I nice set of used aluminum heads can be hand for anywhere from $500-$1,000 depending on the head. And you'll actually make some REAL power with those.
While you're at it...a salvage yard Explorer intake (if you're on a budget) will be a big imrovement over your current E7TE one.
I mean hey, money is tight I know....but if you're willing to drop $300+ on a cam that probably won't gain you much in the line of horsepower anyway, why stop there?
N8Dogg98
3,872
238
184
MN
Sep 10, 2012
#27
  • Sep 10, 2012
  • #27
dammit, every time this thread comes up that damn Missy Elliott song gets stuck in my head
rangerboy101
310
20
28
Inwood, WV
Sep 10, 2012
#28
  • Sep 10, 2012
  • #28
Soooo TFS it is! Haha money is an issue but it isn't....ok I'm on a budget lol
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Sep 11, 2012
#29
  • Sep 11, 2012
  • #29
Just look at my setup i ended up with a tfs 1 cam with a 347 edelbrock heads and a holley systemaxx intake
rangerboy101
310
20
28
Inwood, WV
Sep 11, 2012
#30
  • Sep 11, 2012
  • #30
And how do you like it?
MikeH686
2,843
1,753
184
Waldorf, MD
Sep 11, 2012
#31
  • Sep 11, 2012
  • #31
Dunno aint drove it yet but dynoed at 410 at 4200
Farrell5.0
Not sure what "DP" means, but know's he likes it!
353
299
104
Vancouver, WA
Sep 15, 2012
#32
  • Sep 15, 2012
  • #32
Like I said, I had bigger heads and a better intake with a tfs 1 cam....trick flow wouldn't put it in a kit like that if it were ty. If you want something with great street ability and good power that is the cam. And it sounds great. Just buy the damn thing holy hell lol
rangerboy101
310
20
28
Inwood, WV
Sep 16, 2012
#33
  • Sep 16, 2012
  • #33
That's the answer I was looking for! haha I'm going to just go ahead and buy it sometime this week. I'm looking at swapping the cam and possibly dropping the trans(needs a rebuild) in the next month or so before it gets too cold out.
fiveohwblow
Official Member
2,169
145
155
Sep 17, 2012
#34
  • Sep 17, 2012
  • #34
Dammit N8Dogg98 now you have me thinking about that crappy song when I see this thread.
N8Dogg98
3,872
238
184
MN
Sep 17, 2012
#35
  • Sep 17, 2012
  • #35
fiveohwblow
fiveohwblow
Official Member
2,169
145
155
Sep 17, 2012
#36
  • Sep 17, 2012
  • #36
N8Dogg98 said:
fiveohwblow
ratio411
3,870
73
109
Pensacola FL
Sep 17, 2012
#37
  • Sep 17, 2012
  • #37
What gear ratio are you running?
I didn't see where you ever said...
rangerboy101
310
20
28
Inwood, WV
Sep 19, 2012
#38
  • Sep 19, 2012
  • #38
3.73's
First Prev 2 of 2
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
