  • SN95 4.6L Mustang Tech
Is my clutch going out?
  • Thread starter Thread starter Skidzz
  • Start date Start date May 13, 2007
  • 3
First Prev 3 of 3
Malevolyn
18
Lakeland, FL
Feb 6, 2008
#41
  • Feb 6, 2008
  • #41
I had this same problem (with the flat spots) and it's not a misfire, clutch problem, or fuel filter. Vacuum leak, maybe?
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Feb 6, 2008
#42
  • Feb 6, 2008
  • #42
Sorry it took me so long to respond but, wow, I didn't expect this old thread to be bumped again.
Anyway, my problem ended up just being a couple of bad spark plug wires. The reason I didn't inspect them immediately was because they weren't even a year old. I didn't expect them to be bad, but it turns out I got a bad batch of wires, which also explains why my first dyno run after the PI swap and cams only yielded 245 rwhp. I had it dynoed again after replacing them, and she put down 265 rwhp
2000fordstanggt
404
Westland, MI
Feb 6, 2008
#43
  • Feb 6, 2008
  • #43
i have "flat spots" when the car is parked in gear or when its very cold out.
i didnt even notice it until the fall, when it started getting cold, since i bought the car during the summer.
StuartGT
Maryland
Nov 24, 2009
#44
  • Nov 24, 2009
  • #44
Skidzz said:
Ok, so I just went out for a drive and here's what I noticed:
1. I did the "hill test." It's not the clutch. The clutch is holding fine in all gears.
2. I noticed that the car is bucking any time I cruise at about 2000 rmp's in any gear.
3. It's like the car is just losing power during these flat spots.
Maybe it is a misfire. I still can't tell.
has anyone ever figured out what causes this besides plugs, Maf, coilpacks, vaccum leaks because there are alot of forums with the same problem but no one ever says they found the problem. now my 1999 Gt with a D1sc and a t65 swap is doing it and its driving me crazy trust me im trying to do my research ive checked every plug, wire, conector on the car that i touched and it just consistently jumps to rich at exactly 2000 rpms and almost makes the car sound like its going into 2 step. Please help be the first to post an actual solution on this website haha.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Nov 24, 2009
#45
  • Nov 24, 2009
  • #45
Replace your fuel filter and see what happens. Its easy to do, like a 15 minute job
BTW replacing a fuel injector is not hard. And taking off the entire plenum assembly is pretty easy, all you do is unbolt the 4 bolts and maybe disconnect the air intake from the throttle body and a couple other bolts...you could do it in 15 mins...
  • 3
First Prev 3 of 3
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
