is my fuel injector broken?
MattTheBat83
203
i was taking the caps and washers off to clean my injectors before i put them into my new engine but the tip on one of them wasn't sticking out of the bottom of the injector... its broken right? i have 19 lb injectors should i go higher? my engine is 302 roller motor .40 over with forged pistons gt40 irons with 1.7 roller rockers with gt40 manifolds
Some injectors have 4 tiny holes in them instead of a single pintle pin.
The factory 19 lb injectors are good to 300 Flywheel HP. You are probably somewhat less than that at this time.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit.. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end
