So i hooked about a hand held vacuum pump w/ gauge to the FPR and pulled vacuum, It slowly bled down and when i pulled the pump off and smelled the hose it smelled like gas. So i'm assuming its bad, right? I should have known when i intially installed it since i couldn't adjust the pressure all the much. I could basically pull the entire screw out without moving the psi ~1-2psi. Anyway i just got off the phone with summit and there going to warranty it even though its one month past the 90 day warranty.
This was a sign of a bad one correct?
Edit: I did it with the car off, don't know if that matters and does anyone know how much vacuum i should have pulled and held?
