So I'm doing some final shakedown drives after a multi-month rebuild. It's now a fully built H/C/I with AFR heads.
I had to replace the TFI module due to heat soak, and relocated it to the fenderwell. I did some surface guage temperature tests tonight after driving it to temperature for about 30 minutes. Here's where the temps fell:
Dash: 'M' in normal. (Around ~200 degrees I think)
Distributor Surface: ~143 degrees F.
Head Surface Temp: ~197 degree F.
However, after it was sitting idle for 2 min, I turned the lights on and temp gauge went up to the top. I'm thinking I still have some cooling isues. The fan and fan clutch are stock, but the radiator and water pump are aftermarket.
Looking at the numbers, I think it's time for a 180 degree thermostat, and maybe swap out the fan for an twin electric model (the alt is a 130amp upgrade). Last ditch is replace the radiator. It's about 13 years old now.
Thoughts?
Thoughts?
