Is the rumor true?
  • Thread starter Thread starter KBCobra95
  • Start date Start date Dec 3, 2006
KBCobra95
356
North Carolina
Dec 3, 2006
  • Dec 3, 2006
I am having to drop my motor due to clearnce issues w stock hood and have read numerous times that vert motor mounts drop the motor around 3/4 of an inch. Before I waste money I figured I would ask you fox guys. My only option if the rumor is false is solid mounts. So I really hope this rumor is true. Thanks for any help. God Bless. Andrew.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 3, 2006
  • Dec 3, 2006
Don't they make drop mounts? The vert mounts are stronger but i'm not sure bout the 3/4 inch drop bit.
KBCobra95
356
North Carolina
Dec 3, 2006
  • Dec 3, 2006
I think the drop mounts are solid, aren't they?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 3, 2006
  • Dec 3, 2006
I was looking on summit racing web site and i did not see any drop mounts offered for the 94-95 stangs. there has to be drop mounts though.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Dec 3, 2006
  • Dec 3, 2006
Vert mounts are stronger but i've never seen any proof of a height difference although many people say there is. You'd have to either get solid mounts or a tubular K member to lower the engine.
D
Deleted member 87397
Dec 4, 2006
  • Dec 4, 2006
Just get a cowl hood and be done with it. You aren't going to like solid motor mounts if you drive that thing frequently. Don't know about the drop on the vert mounts. You could also get rid of the thin cross support on the underside of your hood. It won't hurt anything.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 4, 2006
  • Dec 4, 2006
i think hes got a cowl hood now but dosent like that he cant see past it
RYC CUKR
1,437
Orlando
Dec 4, 2006
  • Dec 4, 2006
The older FOX Mustangs did have height differences between the verts and hatch/coupes but by around 91-92 they were the same height. I know that the mounts for my 93 are the same part # for verts and coupe/hatch but the mounts for my 88 have different part numbers for verts and coupe/hatch
D
Daggar
3,902
  • Dec 4, 2006
Be mindful of space between your headers and your steering shaft. Although, it may seem like lowering your motor a 1/4 or 1/8th inch might solve your clearance problems, it may create another issue.
On my 86, the difference between mounts is pretty significant. The vert mounts are a LOT lower than the stockers. I however, do not know how tall the mounts are on later model cars like yours.
Rick 91GT
Mustang Master
95
99
PA
Dec 4, 2006
#10
  • Dec 4, 2006
  • #10
ugghh...I'm still having nightmares about your 4 eye
Yes in the later model it will drop the motor about 3/4" and usually clearance with most aftermarket shorties and long tubes is not an issue.
KBCobra95
356
North Carolina
Dec 4, 2006
#11
  • Dec 4, 2006
  • #11
So pre-91 vert mounts will work on my 95? Yes I already have a cowl hood and hate it. No longer get many races
HISSIN50
34
129
Dec 4, 2006
#12
  • Dec 4, 2006
  • #12
It's been awhile since I looked at early aero fox hardtop mounts but they are NOT something I'd want to use. Nor do I think they are lower than the 5N95 mounts (the 5N95 mounts are pretty pancaked for the hood line).
For edification, I'd run down to the parts store that as all 3 styles of mount in stock and compare them.
The 94-95's are real picky about the mounts (regarding NVH and driveline geometry).
Good luck.
KBCobra95
356
North Carolina
Dec 5, 2006
#13
  • Dec 5, 2006
  • #13
So will fox mounts work on the sn95?
D
Daggar
3,902
#14
  • Dec 5, 2006
  • #14
hehehe... Good Times... NOT!
KBCobra95
356
North Carolina
Dec 6, 2006
#15
  • Dec 6, 2006
  • #15
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
