is there a return fuel line in carb setup?
If it's 510-12-803 then the port on the bottom is the inlet, the two on the sides go to the carb. You can plug one if you only need one.. They're set up for a holley carb with one line to each bowl.
If you have Part #: 12-803BP, then it has a bypass and uses a return line
No return line is used on a properly done carb setup. The single low pressure pump that is required for carb setups puts out less than 10 PSI.
Actually, a good carb setup does use a return line. Even my carbed 84 has a factory return line from the pump.. you dont always NEED it, but circulating cooler fuel to the carb is always a good idea..
That's correct. A properly done carb setup requires a return line if you want any real volume. I run a BG220 HR pump on my car which requires a #8AN supply and a #10AN return. That way the pump runs at full volume all the time and returns what it doesn't need to the tank.
Shouldn't the return be smaller than the supply? Or are you running the return line from the pump to the tank instead of the regulator to tank which is located at the front of the car?
This may be the wrong way to do it, but unstill i can buy a bypass regulator, i have my feed and return ran to a "T" and have the regulator after that then to the carb, that way all unused full goes to the tank, it looks like crap though, but if you can get what you need now, get a bypass regulator, it'll have one "IN" and 2 "outs" one to the carb one back to the tank
The #8 supply runs from the pump to a bypass regulator. I have two #8 supplies to the carb (upstream of the bypass regulator) and then the #10 return runs back to the tank. BG wants the larger return line because the fuel isn't under as much pressure on the return side of the bypass regulator. If not you could get an increase in pressure under certain conditions.
I am running #10 from the tank to the pump and #8 from the pump to the regulator and a pair of #6's to each carb bowl. I was thinking of running a single #6 from the regulator (return port) back to the tank since that is what Ford originally did. I am not having a fuel starvation issue but thought this might help the pump and fuel run cooler but noe sure of the return size?
That may be a good idea, that's the whole idea behind the BG220 HR pump that I run. It's made for lower pump and fuel temperatures for extended street use. My outlets to carb are #6 also, not #8 like I previously posted. Here's a link to the BG pumps and recommended installs.
http://www.barrygrant.com/pages/manuals.aspx
Ahhhh....Now that is totally backward from what I was thinking since the regulator is only on the return side. Which brings up another question about controlling fuel pressure? If you adjust the fuel pressure to 9 psi max will that setup close off (regulator) if it starts to drop?
Yeah, it's different. Think of it this way. The pump is flowing full volume 100 percent of the time. The bypass regulator acts as a restriction on the return. So when you're lowering the pressure you're actually just allowing more fuel to bypass hence lowering the pressure without effecting the volume.
I'm used to just deadheading the pump but at 15psi it does build up heat and starts to cavitate which could fall behind in volume when really needed. I bracket race so I'm always looking to be more consistant on temps. and that is one area that I think can be improved by adding a return. It would probably increase the life of the pump as well.
Yeah on a 94 GT mustang opal Frost with black stripes it's got a pretty good size cam in it probably equal to like a b303 it's a lunatican voodoo I think the max lift is like 554 or something like that but I'm wanting to do a carburetor swap I want to put a carburetor on it and I was just wondering do I plug the return line from the fuel injection system, then run the supply line into a fuel regulator then to the carb for about 7 lb of fuel pressure.
