Caldwell said:Well, you can toss on meatier tires on the rears if the backs are wider with the 9 inch...
i'm running...
i can't remember, my lord.![]()
I dunno, but I got 275/40s on the rear
if i upped my width on the rears, i could probably push like a 315/35
whereas you SHOULDN'T do that in the front.
deep dish 17x10.5 w/ a 315/35 are what i run in the back--hawt1!!xc_myers_06 said:I would say you will see a $ increase for tires with wider wheels. You will feel a traction difference with the wider tires and also they just look much nicer especially from behind the car with big, fat wide-ass tires on it.
I have 275/40x17 all around on a completely stock suspension. I have had no problems with the rear tires and the fronts only rub a little on the swaybar at wheel lock. So, if you use 17x9's with the same backspacing as what the Steeda wheels have, you should be all set.TheDamned said:dont want to hijack the thread but I want to run 275/40s in the back on 17x9 rims on STOCK suspension stuff, it'll fit without problems caldwell ? any tractions issues with those ?
Thanks
if the car has a stock set-up outback, no you don'txc_myers_06 said:do you need wheel spaces with 9" wide tires?
Thanks
illwood said:I have 275/40x17 all around on a completely stock suspension. I have had no problems with the rear tires and the fronts only rub a little on the swaybar at wheel lock. So, if you use 17x9's with the same backspacing as what the Steeda wheels have, you should be all set.
I'm looking at the same thing for my fourth-gen Camaro. Since this is my daily driver with V6 engine, I am keeping the fronts the same width as OEM to avoid adding steering effort in turns. I am adding an inch to the rears to combat wheel slip.
