Is There Supposed To Be Any Play In The Axles?
I'm not following what you are suggesting to do here. I do have stiff knees sometimes but that's from getting older.
And to phatboy, they are Ford pads but I'm finding it strange how the sound went away after messing around with them and now is back but just not as loud. Something is obviously rubbing which shouldn't be.
Stiff-knees are those metal post that sit the axle-tubes on. Heard some "old-heads" call them "stiff-knees," the name stuck w/me for calling them that.
You should be able to track the noise down by PHYSICALLY turn the the rear wheels with the rear-end up in the air. DON'T accel the car w/the front end down and the rear end up, no good is going to happen.
We did that on the rack with the wheel off and the pads out but the lug nuts on to hold the rotor and you couldn't really hear it but like I said my friend saw the rotor moving in and out a little so if the pads were there I would think they would rub. We also ran it with the pads in and he couldn't really hear it but did a little. So it must be something to do with having the wheel on and the weight of the car on there as well.
The guys at the Mustang shop I mentioned before said it can be C clips as well but they only work on engines for race cars basically so they cant do any work for me.
One other question I thought of while we are on the subject is there any point in getting a tune or a tuner for a basically stock car? I know I will need my speedo calibrated after the gears but will any of those "built in" tunes that come with the tuners help?
