I inetwebguy New Member Jun 13, 2024 3 0 1 Florida Aug 18, 2024 #1 Aug 18, 2024 #1 I was converting my 289 from a 2bbl to a 4bbl and when I had the intake manifold off I noticed this 302 stamp cast into the well. Is this just a coincidence or is this 289 actually a 302? Attachments IMG_5124.webp 641.7 KB · Views: 156
89ripper Founding Member Jun 3, 2002 925 309 103 Rockford, Illinois Aug 18, 2024 #2 Aug 18, 2024 #2 https://www.fordmuscleforums.com/threads/lifter-valley-casting-numbers.428810/ Check that link out
I inetwebguy New Member Jun 13, 2024 3 0 1 Florida Aug 19, 2024 #3 Aug 19, 2024 #3 Thank you. Mine is a 66, so clearly not the original block. Now to find out if it’s just the block. Thoughts?
89ripper Founding Member Jun 3, 2002 925 309 103 Rockford, Illinois Aug 19, 2024 #4 Aug 19, 2024 #4 https://www.fordmuscleforums.com/threads/how-do-you-tell-the-difference-between-a-289-and-a-302.448031/ Here is another thread on the subject. Hopefully this will help you
horse sence 15 Year Member Nov 29, 1999 12,469 8,444 233 Wile Coyote's stunt double Aug 19, 2024 #5 Aug 19, 2024 #5 Yes. A 289 says 289 in the lifter gally ,however ,they are actually the same block It is the stroke that makes it a 302 ,you need to check the crank and rods to see if 289 or 302 Reactions: 89ripper
Realmongo I prefer to be called "Evil Genius" Founding Member Oct 10, 2001 2,466 86 99 Western Mass Aug 28, 2024 #6 Aug 28, 2024 #6 A lot of late 289 production engines used the new 302 blocks.
