Ok, its got the stock rad, new thermostat, new water pump. Its got an abnormally amount of white smoke coming from both tailpipes although the passeneger was spitting out more than the driver side. It will over heat while driving, when you shut it off the upper rad hose starts making a bubbling sound and after like a minute of this it will boil over into the reservoir tank and make alot of funny noises like a theres alot of pressure in the system or something. I figured after you turn it off that last few seconds some pistons will be going up onto tdc and since the ignition is off it cant fire so then the compression finds its way through the bad head gasket and throught the cooling system , and into the upper rad hose, and after enough of this pressure is built the rad cap would let it boil over into the reservoir tank.Does this make sense or could there be another culprit for the overheating, whitesmoke, more in one side of the other, magically disappearing coolant.Oh yeah also if it's running with the rad cap off after like 10-20 seconds it will start overfilling and bubbling out and squirting all over. Any ideas Thanks
