Is this a good deal for a T5?
Stang66swt
Texas
Here's the info:
I have a Tremec Transmission for sale $800.00 obo. This transmission sale price is $1295.00 brand new. This transmission only has at the most has 400 miles on it -- 100 after the rebuild. It also comes with a Steeda Tri-Ax shifter with a Pro 5.0 handle. The shifter itself brand new goes for $179.00. The bell housing is also included. I have attached the specs from Jegs website. You can email me with questions. I also have pics, I will add them soon. This is a good deal.
A "World Class" heavy-duty version of the Mustang GT factory transmission. Short throw shifter included.
Features
Die-cast aluminum housings reduce weight
Advanced synchronizers, bearings, and bearing retainer
Tapered roller bearings on shafts minimize noise and wear
Powdered steel core blocker rings & engineered friction materials
Patented strut-type design for durability
Internal, single-rail shift system
Requires 5.62 pints of fluid
1st to 4th gear needle bearings improve high-speed performance and lessen shift effort
5th gear overdrive provides extended ratio coverage
Sliding idler Reverse for simplicity and reliability
Gear Ratios: 1st 2.95, 2nd 1.94, 3rd 1.34, 4th 1.00, 5th .63, Reverse 2.76
Here's the info:
Features
A good deal on a World Class T5 would be around the $400-500 range. I got mine for $450 w/ bell, clutch cable, stock shifter, etc. If you opt for one of these, try to find a 90-93 T5. They're stronger than the 86-89 T5s (which are also considered 'world class'). Don't bother with one before 86 or after 94... they'd work but theres added headaches.
Now, that looks like it may be a T-5z (higher torque rating etc) which is worth more but $800 sounds a little steep for a used one still. I might shell out $600-700 on one, but you only need a T-5z if you're pushing 350-400 ft-lbs or something (ie at least a moderately serious build). Make 100% sure you confirm its a T5z though before you buy.
You could/should ask for the codes on the transmission. A simple google search once you have that code will tell you what you've got.
I'm of the opinion that parts are worht whatever someone will pay. If you can get $800, then that's it's value. Personally, I doubt it will fetch that much, and unless you can prove the mileage, it's just a used transmission. Because I wouldn't know you from Adam, I'd be leary of any and all claims. Ever notice that every used car has a "freshly rebuilt motor" or a "new clutch" or some other non-proveable rebuild? I don't want to sound harsh, but be prepared for a lot of raised eyebrows when you toss that claim out there.
I'm not actually selling it... I just copied the ad of someone who is.
Oh, I must've been thrown off by the first sentence of your post, the one that said, "I have a Tremec Transmission for sale $800 obo". Same rules of thumb apply either way. If it can't be proven (rebuilt, etc) assume it's not true. I typically price used stuff at 1/2 of known rebuilt or new parts.
