Is This Gonna Work?
5.slowmaroon
75
Item Name: 306LR\331\347 Pro Bullet Long Block
Item Price: $6,474.95
Options:
  • Engine size Cubic inches:331
  • Small Block Ford Piston Choices:Flat Top Twisted Wedge -3cc pistons, for use with Trick Flow Twisted Wedge & R series heads.
  • Piston Series Upgrades:LIMITED TIME PROMO. FREE GSX Piston Upgrade normally $200.00
  • Ring Options:Upgrade to Severe duty ductile iron Moly rings
  • Piston Skirt Options:High Precision Diamond turned piston skirts.
  • Upgrade your Block:Level 10 Block upgrade No Charge
  • Your choice of camshaft:Have D.S.S Racing Select a Premium Hydraulic Roller Cam
  • Choose your cylinder heads:TFS Twisted Wedge will handle .600 lift
  • Block O ring Option:No Oring
  • OPTION PACKAGES:SUPER PRO LEVEL 20 OPTION PACKAGE
Not sure what you mean? I'm sure it will crank up and run. Not trying to be a smart butt, your question is just a little vauge. I do think it would be a good engine with good power, just depends on what you are looking for.
Joe
