Is this good turbo cam or .......... ????
Slow5.0
2,554
Portland, OR
Can someone tell me little bit more about this cam and is this cam good for Turbo 8-12psi on (306/331/247)
Advertised duration @ .006____ 270/280
Duration @ 0.050____________ 218/228
Lobe lift @ cam______________.340/.340
Gross cam lift with 1.6________ .544/.544
LSA_______________________112
Please don't go Off Topic
I would stick a stock cam in it if you are going to run a turbo. My brother has a 94 Cobra with a T-64 turbo with tfs heads, intake, etc and at 8psi it made 496hp and right at 600ft.lbs at the wheels so the stock cam is more than enough for a stock block with a turbo kit and will make good power.
Thats what i looking for around 450HP and 500TQ
ernie, your B-31 cam would most likley make more. with the power band to 6500. you would shatter your hp goal. isn't that cam for a power adder?
and also the fact that i want to see what it will do with a turbo. cause i was thinking of swappng out my 2031 cam for the B-31 if my turbo kit ever get installed.
good luck
BTW what is the name (brand and name) of cam that you specifided above?
good luck
Its a blower cam so i would think there are better turbo cams out there. That cam isnt a reverse split which is what i thought is best or better for turbo setups.
Hey ernie, are u gonna upgrade the block?
Yeah,i will post abot that later, now i tryin figure out can i use this blower cam with Turbo,if not WHY NOT
You can use whatever cam you want with the turbo and still probably make enough power to make you smile. Turbos like reverse split designed cams...that B-31 is not reverse split. From just talking to Ed C. and reading on turbomustangs, thats the type of cam you want. Turbos work best with RS cams.
Slow5.0 said:
Well i sound like stupid,but oh well
Whats is reverse split on cam
I dont know specifics or anything. I just know when talking with ed that a stocker will work, but a reverse split with about 230 on the intake and a little less on the exhaust will work better than a stock cam. Ofcourse this is with my setup...not yours. But the same idea should apply.
Hopefully one of the guys will chime in with more cam knowledge. Or just go to hardcore50 and search reverse split. I know one of the cam guys on the west coast i believe do reverse split cams. I remember talking to them back when i was custom cam searching.
