is this K-Member/Coil Over Kit ny Good
It's a QA1 K-member. You can get it a little cheaper here.
http://cgi.ebay.com/ebaymotors/96-0...c0.m245&_trkparms=65:12|39:1|72:1205|240:1318
I've never heard of Eibach making shocks and shocks go in the rear, struts up front or where you referring to Eibach springs? If you meant springs then you would want the kit without coil overs.
Bill
i got this kit now:
Eibach Pro-System Kit
so i just need to remove the springs and k member and it should work right?
are these kits reliable?
Hard to say without seeing the actually struts themselves. That picture is a stock (generic) picture not the correct one for a 99+ car as the lower mounts aren't there. If it's that same style where the strut mounts to the spindle and the strut runs through the spring like a coil over set up then that K-member should work fine, in fact just about any K-member would work as the K-member doesn't come in contact with the strut.
Bill
