Is this normal?
  • Thread starter Thread starter leon_reynolds
  • Start date Start date Oct 2, 2005
L
leon_reynolds
91
  • Oct 2, 2005
I have upgraded my injectors and maf to an 80mm pro m calibrated for my s/c and 42# injectors. Put it all together, and now it will barely start, and no way it will idle. I assume it is running rich, sputters....black coming out of exaust. I have checked and double checked to make sure it is all put back together correctly and have run codes and it all checked out good. I have been told that I may need to tune, but isnt that why the maf is calibrated for the 42# injectors and boost? If you have to tune it to get it all to work, then what is the purpose of paying to have it calibrated? If anyone may know what to check next it would be greatly appreciated. Thanks
6SpeedLX
100
Mass
Oct 3, 2005
  • Oct 3, 2005
im gonna take a wild guess and say the 42# injectors are too big for only 7 psi and like you said your running rich. And from your sig it doesnt look like you have an aftermarket H/C/I combo done so you can i ask why you would run that big of an injector with a stock/near stock engine and a blower...id say try 30 lb injectors, or a H/C/I combo....but im no expert
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Oct 3, 2005
  • Oct 3, 2005
You're deffinently running rich. The MAF only tricks the computer to run with the 42# injectors, but the pulse/dwell cycle of the original 19# injectors are still programed into the ECU. A tune will remedy most of the issues you experience or a stand alone tuner / wideband O2.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 3, 2005
  • Oct 3, 2005
Did you buy your maf new or used? If new - was it purchased recently? If so, I'd contact ProM (or their new incarnation) and talk with them first about what it's doing. It should idle/run reasonably well with their calibration.
Start up can be a problem because the computer holds the injectors open for a specific period of time -- and with 42's compared to 19's you're getting over twice as much fuel at start up -- it's simply flooding. The ONLY way to remedy that permanently is to alter that parameter in the ecu with chip/tweecer/pms. Temporarily you can try starting with the gas pedal on the floor. I believe that keeps the engine from injecting so much fuel at start up.
Here's ideal - have the 80mm calibrated for 19# injectors, and have ProM send you a multi-point (it's like 21 or 31 points) voltage vs. mass flow transfer function. Use your tuning device to load the transfer function into your ecu. Then use your tuning device to select the size injector you're using. That should match things up perfectly. But it won't help the start up fuel issue -- your tuning device should be able to access the tables that control start up fuel -- and reduce it.
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
Digital Self-tuning Forum Oct 25, 2026
roldy
R
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
