Is this normal?
  • Thread starter Thread starter 87WhiteStang1
  • Start date Start date May 28, 2009
87WhiteStang1
182
  • May 28, 2009
About a month ago i had my traction lock rebuilt with new clutches. i went to the track about a week after and both wheels were spinning for my burnouts all night(street tires)... Last night i went to the track and as far as i know all my burnouts were with only the right tire(BFG A/T drag radials). I was sitting there spinning one wheel and then when i let off the brake and started moving forward i felt it kick in. Is something not working right or this normal for the Ford Trac-Loc unit?
skunk21
1,203
Taxachusetts
May 28, 2009
  • May 28, 2009
no this is not normal. It could be that it's not shimmed right or something else is wrong. what kit was used? chances are the car needs to go back the shop that rebuilt it, it's probally loose( the clutches).
dcurtis
688
May 28, 2009
  • May 28, 2009
I agree, whoever built it may not have shimmed the clutch pack as tight as possible. No need to take it back to the shop unless they will tighten it up for free, you can shim it tighter in your driveway if that's what it needs.
skunk21
1,203
Taxachusetts
May 28, 2009
  • May 28, 2009
I only suggested that because in my opinion the shop didn't the job right + he had a shop do it so I assumed he didn't know how. I could be wrong though
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 28, 2009
  • May 28, 2009
I'd say if it were slipping after only a months worth of use, then they'd damn well better pull it and reshim it for free.
Beasty306GT
671
Oxford,Mass
May 28, 2009
  • May 28, 2009
bring it back to the shop...
dcurtis
688
May 28, 2009
  • May 28, 2009
I agree, I was just saying that because some shops will say it is a driver created problem and try to charge him again. If they will cover it for free then take it back to them, if they won't, it is an easy fix.
87WhiteStang1
182
  • May 30, 2009
okay i figured it wasn't normal. The package i used was the ford racing one off of late model resto... I guess i'll have to call the guy who did it and see if he'll take a look at it and adjust it but if he's a dick about it i may need a quick lesson on how to tighten the shims. Thanks
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
R
Suspension Drag Radial Issue
  • Rcdgl
  • Apr 7, 2025
Fox 5.0 Mustang Tech Apr 7, 2025
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Drivetrain Question about rear differential clutch
  • dqureshi06
  • Sep 9, 2024
2K
Fox 5.0 Mustang Tech Dec 19, 2024
