Is this worth it?
Adams91LX
689
12
29
Plano, TX
I found a set of spindles, hub, caliper, rotor, dust shield for a 5 lug swap off of a 1987 Lincoln Mark VII LSC for 75 bucks... worth it?
It's all in good condition... I'm just not sure if I want to spacer. Anyone use spacer's up front?
And lastly.... will Y2k's or 10th anniversary's fit??
Adamslx. You dont need the spindles etc. Your fox spindles will work with the mark rotors. Go buy new mark rotors and youll be fine. and save a few bucks as well.
Without an MC swap, i wouldn't do the calipers as well. The stock MC doesn't flow enough fluid to properly work the 73mm calipers.
The spindles are useless to you too.
Just buy the rotors new and call it a day. Rotors + rotor seals. Prob be around $80ish
Sad news... i was under the impression that the lincoln swap was a possibility...
oh well.. i'll just wait for the right sn95 parts to come by.
