- Mar 30, 2005
- 388
- 0
- 0
Black Sun 5.0 said:I personally think it's the best solution for switching over to an electric fan in a Fox body.
baskin said:Blackcloud, the unit itself can’t draw enough current to take out the link. Either the crimp to the harness wasn’t tight, which made it overheat (I really recommend a ratcheting crimper, 16 bucks will buy a pretty decent one) or the wire shorted. I’d rather see you use the link, because the unit depends on having a reliable connection to the battery. Most of the fuse holders aren’t very reliable in the heat of the engine compartment and don’t provide that. If you would like, I can send you a new link
baskin said:blackcloud; that would probably be how something like that would unfold with a bad connection. Every time it heats up, every thing expands and the connection gets worse, so it heats up more the next time it cycles on, sooner or lator it hits the critical pont where it just melts down. I would guess this is more likely the problem than the wiring being shorted to ground, the insulation is pretty tough on the 10 gauge wire. I would think that once the new link is installed, you'll be back to having a reliable system.
I wouldn't bother with the relay, but given that you would only use it in an emergency, I would just use the 30A bosh relay, it'll run that fan reliably for long enough to get you where you're going.
Just click "reload" and it will take you there.baskin said:Really; I must be having problems with the search function, can you provide some links?
blackcloud50 said:I am unclear about a few things and trying to understand.
1. The power wiring that runs from the FK35 to the battery is of what gauge? 10awg or 12awg?
2. Current ratings of wire sizes I found are as follows:
10 awg = capable of 33 amps which would use 30 amp fuse or link
12 awg = capable of 21 amps which would use 20 amp fuse or link
14 awg (fusible link) supplied in kit = capable of 13 amps which would use 15 amp fuse
How could a 14 awg fusible link allow enough current to pass to the controller if the link is only designed to allow approx. 13-15 amps and the controller can pull a max of 50 amps then down to 35 amps?
What am I missing here?
baskin said:You're missing context. Take a look at the 30A fuses that you have, the wire is made out of the same copper as the 10 gauge, what gauge do you estimate the fuse to be? Maybe 20 gauge?
The rating depends on a number of things, but mainly the length of the wire, the insulation thermal conductivity, and insulation thickness. The cross linked insulation is a lot tougher than what's on the automotive store wiring, this allows it to be much thinner, so more heat dissipates. It also has a much higher temperature rating than both the automotive store and factory Ford wiring
Before you attach the fusible link, take a lighter to the 10 gauge. Hold it there as long as you can. You'll find not only that it won't burn, but that it won't even change properties or color. Now try the same thing on the fuse holder that you bought, it'll probably go up as soon as the flame hits it.
14 gauge fusible link is correct for 10 gauge wire
