Hey all,
So I finally found a free weekend to install my TFS StreetBurner upper/lower -which turned into a four day event after bad weather, a failing water pump, gas leak from a cut injector o-ring, replacing what felt like every d*** vacuum line under the hood, not having a lot of experience under the mustang hood, and helping my friend reassemble his new 383 stroker monte carlo SS
So long story short- everything went back together fine
rlaugh
, but I seem to have lost a significant amount of fuel economy (like 30%), and it seems to stall out quite a bit before it warms up- just randomly at idle, sometimes it seems to happen when I turn the wheel all the way one way or the other.
After searching around the most common problem seems to be vacuum leaks, but I'm sure there are none of those, since I replaced every line that even remotely involves the intake along the way (including those stupid hard plastic ones that break REALLY easily
). So what should I be looking for now?
Thanks! :SNSign:
-So long story short- everything went back together fine
). So what should I be looking for now?Thanks! :SNSign:
Eh, if it gets loud enough to hear it IN the car I'll get worried.
