  • SN95 4.6L Mustang Tech
Issues With 96 Gt- Part Two
  • Thread starter Thread starter KENS89LX
  • Start date Start date Oct 29, 2015
KENS89LX
302
Cross lanes Wv
Oct 29, 2015
  • Oct 29, 2015
I just found a coolant leak, right above #4 cylinder, at the intake. What's the best route a new intake seen one on ebay for about 129.00, or is the gasket a common problem with these 4.6, and what brand of gasket is the best.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Oct 29, 2015
  • Oct 29, 2015
The manifold is probably cracked. Never heard of one with a gasket failure. Even if it is I would swap the intake anyway since it has to come off. Don't get the Dorman intake. Go with the Ford product.
Reactions: 97gtstang01
KENS89LX
302
Cross lanes Wv
Oct 29, 2015
  • Oct 29, 2015
it seems to be seeping where the intake is seated on the head, dont see no crack, thats why i thought gasket. not sure i can afford the Ford, but i will shop around. thanks for the info..
KENS89LX
302
Cross lanes Wv
Nov 17, 2015
  • Nov 17, 2015
took intake off, no crack found new gasket seemed to fix that leak, now it seems to be coming around the rear bolt passenger side, not running out but seems to be wet, should have I put gasket sealant on it?
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 18, 2015
  • Nov 18, 2015
It's not required but might not have been a bad idea. Dry it and see if it continues.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 18, 2015
  • Nov 18, 2015
Just wondering. Did you USE a torque wrench when installing the intake? If so, what torque value was used?
The intake gaskets that Ford uses are very good. However they do depend upon a smooth sealing surface and correct torque. The Ford servce manual recommends torque values 25 Nm (18 ft-lbs)
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
